STARTING THE Z
Old Oct 6, 2002 | 11:54 PM
kevlt250r's Avatar
ON MY Z I NEVER HAVE TO USE THE CHOKE. IF I TRY TO USE THE CHOKE IT WANT START. DOES EVERYONES START LIKE THIS??? ALSO I USUALLY HAVE TO FEATHER THE THROTTLE.
Old Oct 7, 2002 | 12:24 AM
newZman's Avatar
<< ON MY Z I NEVER HAVE TO USE THE CHOKE. IF I TRY TO USE THE CHOKE IT WANT START. DOES EVERYONES START LIKE THIS??? ALSO I USUALLY HAVE TO FEATHER THE THROTTLE. >>
Choke - yes, cold mornings or quad is flooded from being upright.
Feather - yes, most of the time.
Old Oct 7, 2002 | 12:42 AM
RaptorOwner's Avatar
I found out if my choke on my Z is more than half way it wont start so I pull it back about a quarter of an inch and it starts. When I try to pull the choke farther it will just flat out die. My Raptor is not like that, the farther I pull it out it revs up and I think thats the way it supposed to be.;
Old Oct 7, 2002 | 05:29 PM
vooduuchild's Avatar
Read your manual. It says what temps and what choke positions if any you should use. I've followed that, and she starts every single time first try.
Old Oct 7, 2002 | 06:54 PM
terd's Avatar
hey,just imagine having a 400EX,they start but you need to mess with the throttle to keep it idling,there worse than a 2 stroke!
Old Oct 7, 2002 | 07:37 PM
man, I didnt think anything was worse than a 2 stroke.... besides mixing the fuel you have to kick start it and hope it starts before you pass out.
Old Oct 7, 2002 | 08:27 PM
Corpsie's Avatar
When I tried to start my Z on sunday (50 degree F outside) it needed to have the choke kept on a bit to stay idling.
Once it was warmed up, it had no problems starting without the choke.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
