Shock settings?
Old Oct 28, 2002 | 06:03 PM
lt250r91's Avatar
Default Shock settings?
One of the lastest dirtwheels mag. had an article and adjusting shocks. There are also alot of website's that explain the set-up.
Either do a search for it or check out these couple of sites:
Pro-action This is for dirt bikes, but atv use a similar if the same idea of adjusting.
Ohlins This is from cannondale's website on adjusting therer shocks.
Hope this helps
Old Oct 29, 2002 | 12:11 AM
rivermobster's Avatar
Excelent info...thank a bunch. Now I just need to find the spec. for the ride sag somewhere! Anybody have any ideas?
Thanks in advance,
JD
Old Oct 29, 2002 | 02:53 PM
lt250r91's Avatar
30% for rear and 20% for front.
The % is of total travel with the rider on it. If your rear shock has 9" of travel then you should have close to 3" of sag when sitting on it. Same goese for the front. 10" of shock would be 2" of sag when sitting on it.
Nosniborpapa
Sep 19, 2015 07:07 PM
Alex G.
Sep 19, 2015 06:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
