King Quad Problems
Old Nov 11, 2002 | 02:38 PM
wcrook1007's Avatar
Default King Quad Problems
I have a 1998 King Quad. The problem is when I ride for a long or short time it back fires when you cut it off, when you let it sit for a while after ridding It is real hard to start it will crank up then shut off several time,Once it cranks up it will spit and sputter for a couple of seconds. Then it runs fine any help Please?? The four wheeler is all stock.
Thanks: King Quad
Old Nov 11, 2002 | 09:19 PM
KingQuadTeen's Avatar
You might need to adjust the idel speed. My KQ will backfire sometimes after I shut it off but that is when it is really hot.
Old Nov 12, 2002 | 02:45 AM
markdf's Avatar
You might also try to richen the idle mixture about 1/4 to 1/2 turn. Backfire is usually due to a lean condition or an exhaust leak.
I'd try richening the idle mixture. It is under the carb in front of the float bowl, recessed in a tower near the engine side. You'll probably have to loosen the airbox clamp and the intake clamp and rotate the carb enough to get to the idle mixture screw.
Hope this helps.
Mark
Old Nov 12, 2002 | 10:48 AM
wcrook1007's Avatar
Thanks for the help when you make the adjustment on the carb do you turn screw in or out to make the adjustment.
Kinq Quad:
Old Nov 12, 2002 | 11:21 AM
markdf's Avatar
To richen the mixture, turn the screw out (counter-clockwise).
Mark
moneyman01
Jul 11, 2015 08:50 PM
DTroyer01
Jul 3, 2015 07:34 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
ferret3
Aug 4, 1999 08:23 PM
