how fo you tighten a chain
Old Apr 3, 2000 | 08:36 PM
kidco's Avatar
i have an 87 230 quad sport and the chain got really loose how do i tighten it or do i have to take off a link or two ?
Old Apr 3, 2000 | 08:44 PM
Y2K300EX's Avatar
You can tighten it. It is rather hard to explain but I will try to do my best. First get the rear of the quad off the ground. Then, are two 17mm nuts on 2 15cm long bolt (2 of them top and bottom). Loosen the nuts. Then there are two 12mm bolts with 12mm nuts on them. Back them out as far as you can with out them falling out. Try to move the axle forard (or back i can't remember) till the chain gets tighter. Then adjust up those 12mm bolts and nuts. Then tighten the other bolts you loosened. That should be it. I hope this helped or at least gave you an idea how to do it. Maybe someone else can explain it a little better.
Old Apr 3, 2000 | 09:19 PM
86Honda200SX's Avatar
Well guys this is a little different from mine.First only loosen two bolts on the back of the quad and stick some lever into that hole on the axle and push down.Then retighten.That might have meant what you were trying to say Y2K.
1986 Honda 200SX
1986 Suzuki 230 Quadsport
Old Apr 3, 2000 | 09:32 PM
Y2K300EX's Avatar
Actually the 85-86 are a cam type, and 87-88 are like the kind that I described.
Old Apr 4, 2000 | 11:24 AM
trx430ex's Avatar
Here's a tip
As for me...
1st.. check out chain condition. Is it stretched?
You can not adjust a stretched chain. And it will cause you nothing but problems.
2nd If the chain is good....Follow the tip....
Old Apr 4, 2000 | 02:38 PM
jakeh's Avatar
I think you should get a service manual for your machine there cheep!! and very helpful I have a quad sport also but i cant explain how to adjust the chain on the computer. thats why i sugjest the manual for you there easy to read and have lots of picturs I use clymer manuals hope this helps!
Old Apr 4, 2000 | 06:20 PM
cheap I wish!!The clymers are 30.00
Old Apr 5, 2000 | 09:37 AM
jakeh's Avatar
but worth every penny!!
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
