quadmaster belt
Old Apr 3, 2000 | 09:25 PM
demo's Avatar
i just bought a new 2000 quadmaster and have some noise which i belive is coming from the belt hitting the case.this only happens when going down step hills with some wheel hop or on rough trail when slowing down.could anybody tell me if this is normal because this is my first automatic.
Old Apr 6, 2000 | 09:18 PM
c4drm's Avatar
I have a quadmaster also and can't say that I have experienced this.
Is this your first quad? What do you think of it?
I really enjoy mine and think it's an excellent machine.
Old Apr 6, 2000 | 09:44 PM
demo's Avatar
this is my fourth suzuki quad i had a 87 quadrunner 250,97 kingquad,99 quadrunner 500 but they were all five speeds this is my first auto .when i first heard the noise i thought the tool kit was loose in the storage box flying around.i guess to answer your question do i like my suzuki quads 13 years with them and they never cost me a penny.i love them
Old Apr 8, 2000 | 07:39 AM
c4drm's Avatar
Are you on or off the throttle when you hear this noise?
If you're off the throttle when you hear this noise is your EBS working? I know when I am going down steep hills on mine I am general not on the throttle and my EBS is working great and I hear no noise.
Boy in any case, I can't believe the belt is this loose to be hitting up against the casing. Are you getting any hesitation when you hit the throttle?
Are you in low range or high range when going down steep hills. If in high range try it in low range to see if the problems continues.
How many miles on hit?
Old Apr 9, 2000 | 10:10 PM
maxout's Avatar
hey that quadmaster... have you ever sunk it under water?
Old Apr 10, 2000 | 03:12 PM
demo's Avatar
the noise is coming when i leave off of the throttle. the machine is new with only 85 miles on it.this quad has never been underwater. it seems to me like the ebs is working fine but like i said this is my first auto.going to call the dealer right now and see what he has to say.
Old Apr 10, 2000 | 05:29 PM
mtngoat's Avatar
I think my quadmaster is making the noise you're describing, when on the rear brake causing a wheelhop. If so, I believe it's the rear brake linkage "floating", which is normal. Please post the dealer response so I can be sure too. Thanks.
Old Apr 15, 2000 | 10:46 PM
demo's Avatar
well the dealer checked it out. they said it was normal to here this. i still think somehing is not right. iv`e found that if i work down a steep grade slowly and keep hitting the front brakes only it will make the same noise but not as bad.the noise is coming from the front part of the drive belt. is this where your noise is coming from?
Old Apr 16, 2000 | 12:51 AM
Low-Gear's Avatar
Hi Demo, I don't have a QuadMaster, I elected to go with a manual because I ride in a lot of water.
But, I may be able to help you a little. When you go down a hill and apply one of the brakes, the quad has to adjust the other wheel speeds to match the one you are braking. This is especially true on the rear wheels as the back axle is positive traction. This could be causing the belt to jump and hit the case. If that's all it is, it's probably nothing to worry about. Wish you luck with it. If you do decide to put it under water, let me know how it performs. I've been
debating on getting one.
Old Apr 17, 2000 | 01:14 PM
mtngoat's Avatar
demo, my noise is coming from the rear underside of my quadmaster.
