-Steering Dampners-
Old Dec 7, 2002 | 05:45 PM
llknowlesll's Avatar
Default -Steering Dampners-
Does anybody here have a steering dampner? What is the best brand to go with? I am looking for something to take the shaking out of the bars when i go over bumps. Is this what I want?
llknowlesll
Old Dec 7, 2002 | 06:26 PM
CANNIBAL440's Avatar
Don't know if they make it yet for the Z400 but the Scotts damper is awesome! I have one on my Cannibal and I like it better than a piston style damper, 'cause it works without making the steering feel heavy. It only dampens handlebar movement away from center and lets the bars move back to center completely freely. There is also a seperate low and high speed adjustment, which is also very helpful. There are some other companies out there (WER for one) but I don't know if they have this feature. Good luck.
Old Dec 7, 2002 | 07:29 PM
Zilladaddy500's Avatar
Do they help with steering,I mean I drag race a lot,I guess my question is would it help with keeping the quad from drifting,constanly steering to keep the quad straight,the tie rod's and everthing seem's to be good up in the front end,camber just wondering??
Old Dec 8, 2002 | 04:37 PM
I don't a damper will be much help when drag racing. You drift and have to correct because the rear tires are spinning. Unless, maybe you do your drag racing through some nasty whoops!
Old Dec 8, 2002 | 10:49 PM
alright,alright,maybe it was a dumb question,but the drifting was noticed on the ashalt,i know i didnt specify where i was racing,just wanted to know if a damper would help.i'll recheck the tie rod's.
Old Dec 8, 2002 | 11:43 PM
Good idea, and check the toe in. If your balljoints and tierod ends are all good and you are still having a tough time running straight on blacktop I would bet that your front wheels are toed out,or toed in way too far. Good Luck.
Old Dec 9, 2002 | 11:40 AM
Thank's a million CANNIBAL440,DUHHH I forgot about the toe in and was unaware that if the toe was too far in that it would cause this......Thank's
Old Dec 16, 2002 | 01:11 PM
snowscrambler1's Avatar
Back to the question. Is there any dampener yet? Kinda stinks if not! After all this machine has been out awile.Help me if you can.
Old Dec 16, 2002 | 06:40 PM
There are a few dampers out for the Z400. I think denton and pep both make them for your bike. Check Scotts website too, or call them. I'm very happy with mine, and I believe it out performs any of the piston style dampers out there.
Old Dec 17, 2002 | 06:00 AM
I like the sounds of how you decribed this scotts dampener.Can I get the the web address from you.Thanks for your help.
