LTZ-400 Jetting Question
Old Jan 4, 2003 | 08:20 PM
ngtcrawlr's Avatar
Default LTZ-400 Jetting Question
I purchased a Uni air filter and plan to remove the airbox lid. Which size jet should I change to. I have stock exhaust, no engine mods, and live in Virginia at a low elevation, less than 1000 feet. Any input is greatly appreciated.
Old Jan 4, 2003 | 09:56 PM
250EXcited's Avatar
I experimented with my Z alot when I first got it. I found no benefit in removing the airbox lid with the stock exhaust. The stock silencer is very restrictive. It does no good to let more air in if you can't push it out. I would suggest removing the snorkle cover and using a 135-140 main jet. Here's my setup, and it runs great. 1. Removed peashooter from stock silencer. 2. Uni filter. 3. Removed snorkle cover. 4. 140 main. 5. Moved washer from above needle clip to below.
I tried removing the airbox lid and bigger jetting, but none of it worked as well as the above setup. I finally ordered an aftermarket exhaust this week and I'll be running no lid with the new setup. Good luck.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
