air filter Z/KFX??
Old Mar 22, 2003 | 11:38 PM
TeamGrnMojave269's Avatar
Default air filter Z/KFX??
I will be buying a new air filter soon for my KFX 400 wondering which one you guys recommend and if I will need any additional parts other than the filter?
Thanks
Old Mar 23, 2003 | 12:07 AM
bulldogz400's Avatar
I love my pro design filter with adapter, even though it was kind of a struggle to put on. If I had to do it again I would buy a K&N filter and adapter since they seem to flow a little better. Im not sure about what the climate is like where you live, but in Vegas there is no water so a non-foam filter would work just fine.
Old Mar 23, 2003 | 12:34 PM
SuzukiKidZ400's Avatar
I have a K&N and an alba max flow adapter and it hooks up good.
Old Mar 23, 2003 | 12:54 PM
Catch's Avatar
I'm kinda sitting in the same boat as TeamGrn. I do have a question about the adapters I keep reading everyone talk about. Is that a necessity for a K&N because it doesn't fit quite right or is it just another performance mod?
Old Mar 23, 2003 | 12:59 PM
JeffP's Avatar
This place seems to carry a nice adapter setup. Noss Machine I haven't heard anything negative yet. I personally run the CFM aluminum airbox with Uni Filter and thrilled with it's results.
Old Mar 23, 2003 | 06:31 PM
The K&N does not fit on it without the adapter. When u get the adapter it makes the K&N fit plus supposively give better air flow
Old Mar 23, 2003 | 10:30 PM
okay so here is another question....Will I actually be able to tell a difference with a new filter over the stock?
Old Mar 23, 2003 | 10:39 PM
Honestly, just the filter and the adapter alone you wont feel that much at all but with it helps out when you get a pipe on and more engine mods.
Old Mar 23, 2003 | 10:45 PM
yeah I've already got a pipe and I've rejetted it, removed the snorkel, and the air lid.
With the filter that's pretty much going to be all the engine mods I'll be doing for awhile I want to start with the suspension next...a-arms and swing arm and shock
Old Mar 23, 2003 | 10:53 PM
Yea it would be a good idea to get one with the mods you have. you got to let the thing breath
