LT 230
I had a LT230 Shaft and wish I hadn't sold it for only $900.... It probably had plenty of life left in it.... Does awesome wheelies.... Now the negatives... The gas tank on the right side is kinda close if you put oversized tires on it and rubs... They don't like cold weather.... They are really light in the front and tend to flip back on you going up hills... I turned the front tires inside out and put a rack up front to increase the stability...
later
later
inspect the swingarm closely. i think they're notorious for throwing chains & busting motor cases. wiggle the swingarm and if there's any slop, get new bearings. also, look real close for cracks in the pivot tube. i was lucky to find an aftermarket swingarm for mine.
