lt250r carburetor keihin or mikuni
i have an 88 lt250r, my question is, was the stock carburetor a mikuni or a keihin, was it both?
im not , my manual only list the mikuni and i have a keihin carb, i didnt see any markings on it so i dont know if its the 39pwk
im new to the game , so any help i would appreciate
I tried both Mikuni and Keihin on my 87 LT250R and the best carb i found was a ESR Mikuni TMXx 36mm. Starts great and runs like a champ, with easy jet changes. I know a lot of people that love there Keihin, and I know they are good carbs, but don't count out the Mikuni. If you go with a Keihin stay away from the PJ's...they idle like %$#%.
Any of you guys ever add the mikuni power jet modification to their mikuni carbs? I want to try it but I just want to see if anybody has ever done and know what the results were.
later
Superstar
later
Superstar
The TMX is just the newer version. I don't know what they changed but it is suppose to be an improvement over the TM. Mikuni currently makes different versions of the TMX. I have the TMXx which is the Mikuni that Eddie Sanders Racing(ESR) sells. What I like about this model is it uses a screw to raise and lower the slide just slightly to adjust the idle. I have found this simple way of controling the idle is very effective.
