Pro-Circuit Z400 Pipe Help?
Old May 7, 2003 | 01:44 AM
87RaceRider's Avatar
Default Pro-Circuit Z400 Pipe Help?
I've noticed that many places are selling the Pro-Circuit Silencer and Pipe seperate, and not as a full sys. Does anybody know if the Silence will work with the stock pipe? If so I would like to get it and then upgrade to the header later. If anybody has any info, that would be great, because I can't find much from their web site.
Thanks
Old May 7, 2003 | 02:12 AM
Todd400's Avatar
Yeah there slip on will fit the stock pipe, They are like most pipe makers and let us guys with a budget build as our wallet will let us[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 7, 2003 | 09:40 AM
Ok..now I know they make a slip on that will fit the stock pipe, but will it also fit the Pro Circuit header if I want to complete it as a full system. I know that the Yoshi system you can get either the full system or the slip on, but the slip on can only be used with the stock pipe. I just want to make sure I can upgrade to the full system at a later time.
Thanks
Old May 7, 2003 | 09:41 AM
Ouh..yeah, would my jetting change from the slip-on to the full system?
Old May 7, 2003 | 04:44 PM
Motoxracer34's Avatar
when you order the slip on it comes with an adapter sleeve for your stock pipe, then if you upgrade to the head pipe you just don't use the adapter sleeve, stock head pipes are skinnier than the pro circuit head pipe, so that is what the sleeve is for. I just put my system on last week and what a difference, it was a pain in the rear to do the head pipe. As for jetting Pro Circuit said if all you are doing is putting on the pipe then there is no jet changes, but if you change filters then follow the filter recommendation. I would recommend the K&N filter with the adapter made by Alba and when you order the filter from them also get the jet kit they recommend. Adding these mods will make such an incredible difference you will be more than happy.
Old May 16, 2003 | 05:45 AM
Djmz400's Avatar
Does the same apply for White Bros. pipes and headers?
Old May 18, 2003 | 09:31 AM
2000blasterbeater's Avatar
What are you guys paying for a full procircuit system?
And you really don't have to change jetting just for the exhaust? never heard that before really...how is it working out with the full system and no jetting change?
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
