Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Installing a .010 piston
Old Dec 22, 2007 | 08:06 PM
mikeski01's Avatar
Default Installing a .010 piston
I have a 1981 Honda ATC 250R, I am installing a .010 piston, I need to bore the cylinder about .006 to achieve the recommended .002 piston to cylinder clearance. what is the process? can it be honed? is this cylinder nickle plated? if so does it require a sleeve replacement. or do I just have it machined? if so what about the nickle plating if it has it. What should machining cost?
Help!!!!!!!!!!!!!!!
Old Dec 23, 2007 | 08:13 AM
OhHell's Avatar
Just take the cylinder and new piston to a automotive machine shop.
They will do what is needed for usually less than $50.
When you get it back be sure to wash the cylinder good with soap and water, dry it, and put a coat of oil on it.
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
