has anyone ever changed a belt on a harley golf cart?? i can't seem to get it it past the secondary clutch, has to be an easier way then unbolting the engine
you will probably have to remove the secondary clutch and put it inbetween the sheaves and slip it over the primary clutch(if you dont have to remove the primary to remove the secandry.
