Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
anyone ever pressed a valve guide into a head?
Old Apr 14, 2008 | 09:18 PM
jflib74's Avatar
Default anyone ever pressed a valve guide into a head?
Hey i have a warrior with a broken valve guide i ordered a new one and was going to try to press it in myself any tips or tricks what did you use in the press to push it out or in? thanks
Old Apr 14, 2008 | 09:28 PM
500quadvalley's Avatar
If you can find a good socket head bolt long enough to go through the guide and head put a nut and washer on it and pull it in with the bolt but you will probably have to get someone to reseat it I have done a lot these about half you get lucky.
Old Apr 16, 2008 | 12:01 AM
Doctorturbo's Avatar
GOT BOOST!
Freeze the guide overnight and warm the head a bit. Pop it in quickly.
Old Apr 23, 2008 | 09:27 PM
jflib74's Avatar
hey it worked great the new guide went great got the old one out with a brass hammer and punch the new one from yamaha was oversized so i heated the guide hole with the torch and tapped in the frozen guide went in like butta! how much cash did I just save! oh yeah!
Old Apr 24, 2008 | 01:13 AM
GOT BOOST!
Glad it worked out for you. I've done hundreds and hundreds of guides the way I told you to do it. Most went in like yours did. A few did not!!! At $75 bones a piece my boss did not like me to screw up!!!
Now have a good 3 angle valve job put on and your done. Double check the valve seal with solvent.
Old Apr 24, 2008 | 06:30 AM
jflib74's Avatar
how do i do the solvent test? what type of solvent do i use? thanks
Old Apr 24, 2008 | 11:06 AM
GOT BOOST!
After your valve job is done and the head is assembled, prop the head up on a table with the port up. Pour some gas in the port and fill it up. If the valve job was done correctly, you should see no leakage past the valve. If you do, the valve job was not done correctly and needs to be fixed before the engine is put back together.
Hankey Pankey
Jul 31, 2015 05:50 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Jul 2, 2015 01:34 AM
