Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
1986 SUZUKI LT 230 won't start
Old Oct 29, 2008 | 05:33 PM
kclmarshall's Avatar
Default 1986 SUZUKI LT 230 won't start
We recently got a 1986 SUZUKI LT 230. has run gr8. hubby took it hunting, brought it home, ran it around for a while, all was fine, since then it will not start. Will not fire. Nothing, changed the plug, everything looks fine. You can jumb kick it all day and nothing, before this it always fired in 1 or 2 kick starts.
Will not even start on a down hill roll.
HELP, not sure what has happened.
Hubby ordered a manuel on ebay, should be here next week.
any ideas, tips, would be wonderful.
thanks,
Old Oct 29, 2008 | 05:52 PM
JustRandy's Avatar
Kill switch on? Kill switch shorted? There is one wire that goes to the cdi that, when grounded, stops the spark. If the kill switch is shorted, that wire may be grounded.
Check all wiring for anything obvious....
Old Oct 29, 2008 | 07:49 PM
Thank you for the help,
so far all the wires and everything is looking ok, we have gone over all wires over and over, just seems so strange. working fine, and then 1 hr later nothing haven't been able to get it to start for 2 weeks.
again thank you
Old Oct 29, 2008 | 08:07 PM
JustRandy's Avatar
Are you sure it doesn't spark at all? Maybe a carb problem? The spark can be hard to see sometimes.
If you have an ohm meter, you can check all the coils...
Ignition coil: Primary: 0-2 ohms, Secondary: 10-25k ohms
Magneto: Pickup coil: 100-200 ohms, Power coil: 150-350 ohms, Lighting coil: 0-2 ohms.
If all those pass, its probably the cdi.
Old Nov 6, 2008 | 08:30 PM
swampyjunior's Avatar
You need to know if its a fuel problem, or spark problem.
I had an old suzuki LT250 that would do something similar. It would run for a few minutes until it got hot then stop working. I discovered by accident that the CDI was shorting out internally. Replaced it and it ran fine after that. But, when it acted up I would check all the other wiring connections and still had zero spark. Some snow accidently fell onto the CDI and after it melted and cooled it it ran fine.
I had already emilinated the kill switch, Neutral relay, and the coil and checked the fuel flow.
SJ
Old Nov 23, 2008 | 09:32 AM
cascade quadracer's Avatar
you can get an inline spark plug checker really cheap and they work great. picked mine up at harbor frieght for about 2 bucks. I'd check spark then check fuel. if neither check out the stator.
Old Dec 9, 2008 | 06:59 PM
mubboy's Avatar
where did you get yur cdi cuz mine just died and i need to get a new one and my local atv shop wants to charge me 283 for just the cdi
Old Dec 9, 2008 | 07:11 PM
Mubboy,
It was just easier for me to take it in the shorts and order it from the dealer. After the fact I found a place in Canada that rebuilds CDI's and you might check and see if Moose or one of the newer aftermarket CDI companies make one for your machine. But $238 is not bad.
Later I opened up my old CDI and found a corner of it fried and black. I also discovered it had been leaking moisture into the case.
kclMarshall has some things he should check before he starts replacing expensive things like the CDI though.
Old Dec 9, 2008 | 08:52 PM
mubboy's Avatar
i found this and they say its for a quadsport do you think it would work for my quadrunner its also a 1986 and a LT 230
http://cgi.ebay.com/ebaymotors...3AMEWAX%3AIT&viewitem=
neilbedwell
Nov 10, 2018 11:02 AM
Wromberger2016
Jun 22, 2015 02:07 PM
TJM
Jun 11, 2015 01:28 PM
1000gade
May 27, 2015 12:37 PM
SP335AOK
Sep 6, 2000 09:38 AM
