Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
250ex tranny issue
Old Nov 2, 2008 | 04:08 PM
fireCapt911's Avatar
Default 250ex tranny issue
HELP. i have a 01 trx250ex. It creeps a lot when the clutch is engaged... idk if this is bad. But the main issue is that after a little riding you cannot get out of reverse. I have to shut it off, go to nuetral and then restart. It gets very very frustrating. I am thinking the clutch is shot...
Old Nov 3, 2008 | 10:29 PM
ok. I took the whole quad apart. I have the engine split on the bench. The smaller chain...i believe is for reverse is very loose, I believe this is causing it to be locked in reverse. I am now torn if I should take the clutch apart because that may be worn as well.... any input?
Old Nov 9, 2008 | 01:48 PM
salohciN's Avatar
Might as well if you're already working on the engine. Better to be safe than sorry. And even worse to get everything back together, and then have to replace it anyway in 2 months, right?
COFatboy
May 2, 2020 12:06 AM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
