Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Piston on blaster sometimes catches and stops it from turning over
Old Oct 2, 2011 | 04:18 PM
HMT Racing's Avatar
You will nee a flywheel puller, also get in touch with herr jugs racing, Kevin is a 2 stroke master. Sorry you were taken on this deal. How did the piston, rings, and cylinder wall look after running lean???
Old Oct 9, 2011 | 03:29 PM
Danec44's Avatar
I bought a new Wisco crankshaft, bearings and seals for it. It took three days of taking it apart, cleaning everything thoroughly and reinstalling all the new parts in it and then another day of reassembling it and remounting the engine.
I am waiting on My new piston, rings and top end gaskets.
When it ruined the old/new rings the cylinder didnt have any damage that can be detected. It may be glazed but I cant tell that yet.
I am hopeing that with the new piston and rings that it wont have to have another bore job done on it. It was only ran 20 minutes on the last top end rebuild when it ruined the rings and put 2 knicks on the very top edge of the piston ( due to bad rod and Crank)but I dont see any damage at all in the cylinder so I am hopeing that I can get away with not boring it again. Any ideas?
Thanks Dane
Old Oct 10, 2011 | 09:30 AM
Doctorturbo's Avatar
GOT BOOST!
You won't need to bore it if it only ran for 20 minutes.
It would be a very good idea to re-hone it though. Even a ball hone would be good enough.
Let us know how it goes.
bzdok1234
30
Feb 23, 2016 01:55 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
toonces
Jul 11, 2015 12:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
