Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2000 Polaris Scrambler CDI Box
Old Feb 2, 2013 | 03:35 PM
Joe M Wells Jr's Avatar
Default 2000 Polaris Scrambler CDI Box
Can anyone give me some tips on how to check my CDI modual?
Thanks
Old Feb 2, 2013 | 03:59 PM
Welcome! Basically you have to eliminate the stator and coil as the main culprits as there really isn't a good cdi test in the manual. You have to ohm out the stator wires going into the cdi module . According to the manual on the 2000 model: Red to Green 1.6 ohms, Black/red to Green 446 ohms. Coil primary tab to ground 0.3 ohms. Coil secondary (plug end to coil tab) 6300 ohms. These measurement are + or - 20%. More often than not the stator is the main source of problems on ignition. OPT
Old Feb 2, 2013 | 04:49 PM
None of the leads on the CDI should go to ground correct?
Old Feb 2, 2013 | 05:50 PM
The black one will for sure because it's the ignition kill wire on the cdi and grounds to kill it! As far as for the rest,I don't really know! Stands to reason they shouldn't,but you need to either test the other components OR replace the cdi with a "known" good one to test the ignition as the manual says. OPT
Old Feb 2, 2013 | 06:00 PM
I have isolated and checked the other components and seem to be ok. When I check the wires on the CDI all of them go to ground except the black one. Thanks for your input.
Old Feb 14, 2013 | 05:17 PM
tekrsq's Avatar
OPT,
Are any of those aftermarket "performance" CDI boxes worth the investment ?
Old Feb 14, 2013 | 09:37 PM
That you'll have to ask someone that's tried em! Any time I had to replaced any electronics I stayed with oem.
Old Feb 15, 2013 | 09:42 AM
TLC's Avatar
TLC
Originally Posted by tekrsq
OPT,
PROCOM offers CDI ignition boxes with more aggressive ignition curves and higher RPM limits to get maximum performance from your ATV. $160.
Aaen Performance - Suzuki - Honda ATV Accessories
Old Feb 15, 2013 | 09:49 AM
Just one of several posts on aftermarket "performance" ignition parts. I wouldn't trust any of em! Do Not Buy Procom Procducts!!!! Need Help - Polaris RZR Forum - RZR Forums.net
Old Feb 15, 2013 | 05:36 PM
tekrsq's Avatar
Thanks OPT !!!
