2001 polaris trailblazer
My 2001 polaris trailblazer will run for 30 min and then it stops and wont start for 20 min or so. Any ideas??
Last edited by trailblazer166; Apr 13, 2015 at 09:38 AM. Reason: not enough attention
Check compression. Probably as it warms up the rings are loosing contact with the cylinder wall and dies.Too much clearance Common problem if this is the case. If compression is 100 psi or lower,time to look at the top end.
