Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Vacuum Piston maddness
Old Jan 13, 2016 | 05:42 PM
JerryB4's Avatar
Default Vacuum Piston maddness
Any one have any idea on how to reseat the vacuum piston on a Keihn CVK carb?
My 94 kawasaki was leaking fuel from the float bowl so I thought a new float needle would helpout, as I had the complete kit figured might as well renew all--wrong--spent 2 hrs trying to get vacuum diaphragm back in the groove, really do not want to put out $140.00 !! to replace a intact diaphragm, It seems like the diaphragm is stretched?
Thanks
Old Jan 14, 2016 | 03:22 AM
Gas vapor along with age can cause these to stretch over time. You can try a nice warm,dry place other than a microwave for a couple days and see if it can shrink a little. Wouldn't advise using rtv around the lip to hold the diaphragm in place until you got the cap back, but only as a last resort.If it doesn't work,time for a new one.
Old Jan 14, 2016 | 02:18 PM
JerryB4's Avatar
Thanks OPT, Will give a try.
Old Jan 19, 2016 | 04:58 PM
Fasteratv's Avatar
Put a little grease in the groove, all the way around the groove....thro the diaphragm in the freezer....yep...the freezer side of your frig. This will cause the diaphragm to shrink, then possibly fit. Handle it with care...
GamMattic
Feb 2, 2016 11:00 PM
mustangmatt70
Jan 16, 2016 09:04 AM
Streetstock174
Jan 13, 2016 07:59 AM
Kawasaki360
Utility ATVs
Jan 2, 2016 04:15 PM
russmt
Dec 24, 2015 11:09 AM
