Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
1993 Timberwolf 250 engine splitting
Old Feb 3, 2016 | 09:39 AM
sefh3's Avatar
Default 1993 Timberwolf 250 engine splitting
I'm needing some help. The bolts on the flywheel/rotor assembly broke. It wiped out the stator. Problem is I only found 1 peice the at was broke off. I fear the other 2 fell down into the case. I hear something rattling after I removed the engine. So my question is, how do I split the case on this. I have the top end off. What special tools are needed? Can I heat (with heat gun) the case to make the bearing slide off? Any help would be great.
Old Feb 3, 2016 | 05:11 PM
Flexible magnet?? May or may not help get all trash or metal parts. If you have to split the engine nothing better than the manual. Found this one and down loaded to see if it was good. Shows to be a good shop manual that has step by step with good illustrations on engine tear down and assy.Best thing is that it was free..https://www.google.com/url?sa=t&rct=...msHLZg&cad=rja
Old Feb 4, 2016 | 07:08 AM
sefh3's Avatar
I tried the magnet. I just don't feel comfortable not knowing if anything else is in the case. Thank you for the manual. I need it.
Old Feb 4, 2016 | 07:11 AM
sefh3's Avatar
hmm I can't open the manual. Says I need a user name and password
Old Feb 4, 2016 | 07:59 AM
Strange as it opened up for me on Adobe Reader.. Found another one,but it's 10 bucks which is better than some.https://www.tradebit.com/filedetail....ice-manual-pdf
wamulass
ATC 3-Wheelers
Jan 10, 2016 06:04 PM
sawtoothfarm
Dec 29, 2015 06:35 AM
Leadfinger
Dec 19, 2015 09:34 AM
Elmer1199
Nov 24, 2015 03:15 AM
