Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Rzr ranger 800
Old Apr 9, 2016 | 09:38 PM
Biggedybagz's Avatar
Default Rzr ranger 800
Have a 09 rzr ranger 800 and I am not sure the awd is working. The switch is in and the night is in and the icon in the screen comes up and don't look like nothing is working
Old Apr 10, 2016 | 01:28 AM
greg74's Avatar
I would think the steering would get noticeably heavier in awd. The way I have always checked any full-size 4x4 I bought to see if 4x4 worked was to simply find some dirt or loose gravel and hit the throttle hard from a dead stop. If the wheels spin easily, no 4x4. Even in ice and snow, in 4x4 its hard to spin the tires from a dead stop.
Old Apr 10, 2016 | 03:34 AM
Easy to check if you have a couple jacks to jack up the front and rear tires off the ground a little. On the ground the front wheels wont kick in unless the rear tires loose traction,kicks out when the rear regains traction.With all tires in the air you can tell if the system is working or not. All earlier models did have problems on some plastic roller cage cracking in the front diff. Optional aluminum ones are offered,but expensive for oem parts( Item #24 (opt) aluminum cage.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If that's the problem cheaper ones are offered on ebay.Polaris RZR800 RZR s RZR 4 Front Differential Billet Roller Cage Sprague 3234466 | eBay Plus there are videos on replacing cracked plastic cages.
mossygoose
11
May 12, 2016 04:15 AM
woollady
10
Apr 3, 2016 11:03 AM
Ticocg59
Mar 20, 2016 03:03 PM
Msoll13
Mar 16, 2016 08:24 PM
