Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
disc brakes on 99 bear tracker
Old 05-31-2017, 09:56 AM
intheworks's Avatar
Default disc brakes on 99 bear tracker
I have searched and have not found much. I have a 99 bear tracker that has front and rear drum brakes. I get into water and they quit completely and even after letting them dry they barely work. Curious if there is a disc brake conversion kit that utilizes the cable instead of brake fluid? Or any advice on drum brakes in water would be helpful....also sorry if this has been covered I have searched a bunch..LOL
Old 09-11-2017, 10:31 PM
Victor84's Avatar
I just did a disk brake conversion on my 99 bear tracker it's simple to do. I think the 04 bear tracker comes with disk brakes so all you need is the spindle assembly with the rotors brake calipers brake lines and master cylinder all is available on eBay
