Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Loncin quad 90cc
Old Feb 26, 2023 | 03:50 PM
fhorta's Avatar
Default Loncin quad 90cc
Hello all. I'll keep short:
ASSUMING there is gas going to carb, carb is good, air filter is good, there is spark from spark plug, quad will not start. Battery has a charge of 11.99 v.
When I press start button and brake, it cranks, but no ignition though.
I tested solenoid by touching posts and I also get a crank.
Here things I recently noticed which seem fishy; maybe. I don't have to push brake to get a crank.
But if I push brake handle away a little, then no crank at all. However, key amd on switch do have to be in the on position or else no crank.
Also, when I touch terminals on solenoid, I get a crank wether key and on switch are off. Is there a starter on this things that maybe is maybe out? Ideas, suggestions much appreciated.
nukeit4me
1) Engine problems..
Aug 16, 2019 09:28 PM
Groderick
3) General Discussions..
Aug 19, 2018 10:18 AM
DevoutOccamist
Mar 3, 2014 02:17 PM
Tyler Stonko
Aug 14, 2013 07:43 PM
black125
Apr 25, 2011 07:12 AM
