never worked on atvs
2002,honda foreman 450es,electric shift will go into reverse neutral and first gear only. when you push shift button you can see manual shift shaft moving,but will not shift beyond 1st. if i try to shift gears manually it still will only go into 1st gear but the 1 on the display will begin flashing and will continue to flash until the key is turned off and back on.Does this signal an internal problem,or does anyone have any suggestions of what might be wrong.
You could find one on ebay I'm sure.
Good luck.
