E track installation
Old May 7, 2009 | 10:04 AM
sparks1032's Avatar
Default E track installation
anyone install this stuff? everything i have seen is recessed and I am not sure I want to do that. Can I install it on top of my plywood and it still will work?
Old May 8, 2009 | 06:38 PM
Speeddrive1's Avatar
yep, lay it down on the floor and screw it down. I put a wood screw in every other hole in my enclosed trailer and have never had any problems with it. Only thing with E track is if dirt gets in the track it might get hard for the strap clips to lock in. Use a shop vac and suck the dirt out and should be good to go.
Old May 8, 2009 | 09:25 PM
DesertViper's Avatar
Here is the etrack I installed. You can see it is not recessed. I do use the plastic end cap pieces that prevent the square ends from snagging your foot and tripping you, and because they give it a more finished look. I used lag bolts in every third to fourth hole, and every third bolt is bolted to a frame crossmember instead of just being screwed into the wood. I've never had any problems with the etrack coming loose, and even use it to tie down a 4100 lb Challenger, and a 4300 lb Jeep.
ReconBayou
Oct 31, 2022 05:37 PM
Oct 10, 2015 10:20 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
