99 Honda Freman 450ES tire&rim?
Old Feb 20, 2014 | 06:18 AM
bwright132's Avatar
Default 99 Honda Freman 450ES tire&rim?
I have been looking at putting a set of 12X7 rims with possibly 27X10-12 on front and 27X12-12 on the back. Do I need to be concerned about offset. Will I need a lift kit?
Thanks in advance.
Old Feb 20, 2014 | 08:31 AM
TLC's Avatar
TLC
I wouldn't I had a 2001 450ES and it would struggle with over sized tires like that even on packed flat trails let alone Mud or inclines.
You will need atleast the gear reducers http://www.ebay.com/itm/NEW-HONDA-FO...-/390319735576 with tires that big with the 24hp OHV 433cc turning them.
A 680 Rincon would struggle with those size tires.
Big mud tires in a mud hole or going up a steep incline do no good if they can't turn.
Old Feb 20, 2014 | 09:42 AM
bwright132's Avatar
Default Thank you for your reponse
would the 26" tires be ok without the gear reducers?
Old Feb 20, 2014 | 11:43 AM
TLC's Avatar
TLC
It goes by tire weigh. My 26x11 with 1.19" lugs Zillas are as light as smaller 25x10 with a shorter 1" lug Mudlite XLs.
Even though Zillas are taller and wider.
Here is a good site that give you tire specs of all brands. Keep a eye on tire weights and lug depth.
ATV Mud Tires : Best ATV Tires
Maxxis Zillas are the lightest 6ply mud tire made with a aggressive lug. http://www.mud-throwers.com/inc/sdetail/6590/12045 That's why I chose them for a 350 4x4.
27x10 on the front is a large heavy tire. You can reduce weigh by reducing the width and leaving the height alone.
Old Feb 20, 2014 | 12:57 PM
sr.ruedas's Avatar
Originally Posted by TLC
You will need atleast the gear reducers New Honda Foreman 400 450 Gear Reduction Kit TRX400 | eBay
That's a very interesting option. I wonder why more folks don't use a
kit like that. It is not an unreasonable cost at all.
I have had the 04 Foreman 450FE, and currently use my TRX300FW all the
time to get up my 40% trail on my property (with new AT489s). I would
not want to lose ANY torque at the wheels. If anything, a smaller tire
diameter would be attractive, even with the lower clearance.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
