Trucks and Towing, All Makes and Models. Discussion on all makes and models of trucks and towing.
Ford Crew cabs w/7.3 Diesel
Old Jun 28, 2007 | 02:34 PM
  #11901
Whitewater's Avatar
Default Ford Crew cabs w/7.3 Diesel
The axle brackets I just bought are probably the spring perches that you speak of. And yes, six inches would be nice.[img]i/expressions/face-icon-small-wink.gif[/img]
I just need to unbolt the u-bolts, weld the spring perch on, and rotate the axles upright again. Right now my tires toe out a little bit.
Old Jun 29, 2007 | 02:29 AM
  #11902
rescuediver's Avatar
Skinner, Like the new icon[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 29, 2007 | 02:30 AM
  #11903
<div class="FTQUOTE"><begin quote>Originally posted by: BlackandRedWarrior
<div class="FTQUOTE"><begin quote>Originally posted by: rescuediver
Well the in-laws are out from Illinois[IMG][/IMG][IMG][/IMG] Already had a azz chew from the mother in-law on the way home from the airport[IMG][/IMG] Guess we get to go to Oceano this weekend. Maybe I'll bury her in the sand and like everything else you bury in the sand, loose her[IMG][/IMG]</end quote></div>
It is at times like these that I'm happy to be single. [IMG]i/expressions/face-icon-small-happy.gif" border="0[/IMG] [IMG]i/expressions/face-icon-small-wink.gif" border="0[/IMG]</end quote></div>
Yea, but the wife is trying to keep me happy[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 29, 2007 | 02:31 AM
  #11904
<div class="FTQUOTE"><begin quote>Originally posted by: Trasher
I wouldn't be flipping the axle 180[img][/img] You just need to get some spring perches welded on the top of the axles so the spring will rest on top of the axle and not bolted from underneath. That should give you about six inches of height to the trailer. (I'll leave the joke open for you here)[img][/img]</end quote></div>
Exactly what Creator said[img]i/expressions/face-icon-small-wink.gif[/img]
Hoss, sounds like you got her fixed now. Are you doing this yourself? If so, pictures[img]i/expressions/face-icon-small-wink.gif[/img] I'll be looking at the same project this fall.
Old Jun 29, 2007 | 03:36 AM
  #11905
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Skinner, Like the new icon[IMG][/IMG]</end quote></div>
First one to say anything. Zone it went unnoticed/unsaid.
I've decided if I ever get a PSD (hahaha) that's the plate I'm gonna get. Should be interesting explaining it on the request form.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Jul 2, 2007 | 01:03 AM
  #11906
I've decided if I ever get a PSD (hahaha) that's the plate I'm gonna get. Should be interesting explaining it on the request form.</end quote></div>
LOL! that's a great idea for a plate[img]i/expressions/face-icon-small-smile.gif[/img] Your onto something there[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 2, 2007 | 01:06 AM
  #11907
Just got back from Pismo, seeing more bigger and better towing rigs down there[img]i/expressions/face-icon-small-shocked.gif[/img] Saw 5-5 Kodiac 4500s and about the same in the F650 category[img]i/expressions/face-icon-small-happy.gif[/img] One F650 went all the way to Kentucky to get his custom paint job. Good looking truck.
Old Jul 2, 2007 | 01:09 AM
  #11908
Skinner, electrical question for you. My Honda 5000 generator stopped making electricity. Last time it did, the GFI circuit breaker kept tripping. Now, I can't get it to trip when I test it. The switch on the breaker flips or trips real easy, kinda like a house light switch. Should it be stiffer? (That's a loaded question[img]i/expressions/face-icon-small-shocked.gif[/img]) and is there a way of checking the breaker before I pay an arm and a leg? Reminder, I am not real good with elelctricity[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 3, 2007 | 10:55 AM
  #11909
powerstroke01's Avatar
Just got back from Pismo, seeing more bigger and better towing rigs down there[img][/img] Saw 5-5 Kodiac 4500s and about the same in the F650 category[img][/img] One F650 went all the way to Kentucky to get his custom paint job. Good looking truck.</end quote></div>
You see my parentals down der? They got down there on the 29th and wont be back till the 9th.
Old Jul 3, 2007 | 12:34 PM
  #11910
Air Cooled Rider
Skinner, electrical question for you. My Honda 5000 generator stopped making electricity. Last time it did, the GFI circuit breaker kept tripping. Now, I can't get it to trip when I test it. The switch on the breaker flips or trips real easy, kinda like a house light switch. Should it be stiffer? (That's a loaded question[img][/img]) and is there a way of checking the breaker before I pay an arm and a leg? Reminder, I am not real good with elelctricity[img][/img]</end quote></div>
If a GFCI is constantly tripping it's usually one of 2 things: there's a ground fault somewhere and it's behaving perfectly normal. 2, it's gone faulty. aka NFG (let you're mind wonder on that means.) Will it trip without a load? Trip with any load? Only trips with a certain load? Without a load I'd say it's bad. It should just be sitting there looking pretty. With any load, sounds like it's gone bad. With only a certain load, check the load for a ground fault. Chaffed cord or such.
And since it's not tripping on test, that's pretty much a bad thing. Are you getting any power from any of the receptacles? If not then the generator itself (stator) could be bad. And yep, those go bad too. With a 5K set, there's probably a 30A 240V 1phase receptacle on their. If you have a meter check for power there. If there isn't, the main breaker could be bad (generally breakers are stiff. (loaded comment))
To check the breaker check for voltage on the line side (incoming from the generator). The breaker should be a 2 pole unit. Which means you'll have 4 wires, 2 line and 2 load. If there's voltage on the line side, but no voltage on the load side, then I'm gonna go out on a limb and say it's bad. [img]i/expressions/face-icon-small-wink.gif[/img] If there's power on the load side and it goes off and comes back with the breaker then the breaker is good. Just start tracing down to the individual receptacles.
I'd suggest wearing some leather work gloves just in case there's a ground fault on the generator itself. No bare skin and only 100% cotton clothing. And I mean ALL clothing. You can test with a continuity tester first. Ground receptacles should buzz out to the frame as well as the neutrals. The hot shouldn't.
