05 grizzly making noise. help please!
Anyone experience a clanking noise coming from the front diff while making low or moderate speed turns? Only happens in two wheel drive. It almost sounds like something is sliding back and forth in the diff.
This is normal if you are breaking at the same time. Mine does that as well as all of the new Grizz owners. It has something to do with the clutch. Don't worry, you will get used to it. If it does it while going down a hill and braking at the same time, that is normal too. You can do a search on here and get the technical explanation. Later, TW
http://forums.atvconnection.com/sear...esttimeout=500 Copy and paste that to your address bar on top there and hit enter. That will take you to the search page and there you go.
RedRancher
Oct 15, 2020 01:45 PM
