Hooking up bumpers/pulling against each other
Old Oct 5, 2004 | 09:40 AM
  #41
zorro700's Avatar
Default Hooking up bumpers/pulling against each other
Yamaha can make power can't they?
Old Oct 5, 2004 | 03:56 PM
  #42
4x4zealot's Avatar
yes they can. they may not be able to put it to the ground as well as a polaris, but IMHO thats all cuz of weight. although ill the sp700 some credit, handled pretty good considerin it was 720lbs. still prefer my scrammy, but that aint winnin no tug of wars around here thnx to the fact everyone runs sportsmans, w/ the exception of one foreman. i still refuse to get a sportsman due to my aggressive ridin style, but theyre great for what they were made for. anyone here seen an ac650 vs sp700?....always wanted to see how the cat faired
Old Oct 16, 2004 | 03:28 PM
  #43
Dirtydude's Avatar
If you want to win a pull competition then get the biggest nastiest tires you can get on your machine, like the Agriculture tires. When you install the farmer tires fill them with calcium. This is what farm tractors use to get massive weight which = more traction. Get them aired down so the sidewalls flex some (not too much or the tread will collapse) Now that you have huge traction now you need to find the optimum hookup point, if you hook up too high the front will come off the ground too easily and you'll have to back off the throttle to not go over backwards. Even on 4x4's the main traction is on the rear of the quad, that said chain driven quads will probably have an advantage over an IRS quad because of the way the torque comes off the top of the sprocket. With the pulling power coming off the top of the sprocket this pull the axle upwards thus squats the quad creating more power transfer. It also depends on how your opponent hooks his quad, if they hook up high on the quad and you hook low then he could steal your power transfer and lift the rear of your quad while increasing his own power transfer and then increasing his total pulling capabilities. I would suggest a long tow rope to lessen this factor or a short one if your wanting to use this tatic yourself.
Another thing that would make quad pulls not equal would be when the 2 pullers applied power, if one quad applied the power a bit faster he could get the power transfer down faster and start the other quad moving which would decrease it's own pulling power (get it spinning slightly) but if he dug a hole then you'd have a harder time pulling him and it would be a stalemate. If you pulled on a hard surface such as pavement then that would change things drastically, now you would want different tires such as slicks and you would want to heat them prior to the pull
It would be very difficult to set up a fair quad vs quad pull by hooking up the bumpers to each other as there is too many factors to consider,
Old Oct 20, 2004 | 11:42 PM
  #44
4wheelerfred's Avatar
ah i can jast hook any quad up to the back of my farmall 560. haha that would be fuuuuunny.
ten quads could not even budge it. 1st gear,tork amplifier on,gas half up,yall better be reddy for a woopin. bad a$$ motherf*ck*r **** s*cker power, wooyeah that took some efort.
Old Oct 21, 2004 | 02:40 AM
  #45
Bradracer18's Avatar
I'll hook up to you.................
With our JD8400............[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 24, 2004 | 06:53 PM
  #46
sp600towtruck's Avatar
Originally posted by: dragomni
Which machine would pull a Grizzly around? This is a serious question that may affect what I buy.
I'm thinking the SP600s and up may be able to pull it being as it is far heavier than the Grizz, it should spin its tires while the heavier machine pulls it away.
How about the BF750?
Or the KQ700?
The Polaris has the highest towing rating, is this just based on its weight advantage/being heavier duty construction?
My Sportsman 600 can drag my buddy's Grizzly 660 around on any surface. He might be a gnat's *** faster in a drag, but he knows better than to hook up to me. (I've dragged him about 7-8 times already, on concrete, asphault, grass, mud, snow, wet grass, gravel, etc., and all of the results are the same. The Polaris won![img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2004 | 12:56 AM
  #47
batmanacw's Avatar
I would rather have my light and agile griz than a tank that wins because its way heavier. I am sure that if you loaded the griz to the same weight it would not be so easy.
Old Oct 26, 2004 | 09:23 AM
  #48
Originally posted by: batmanacw
I would rather have my light and agile AND TOP HEAVY griz than a tank that wins because its way heavier. I am sure that if you loaded the griz to the same weight it would not be so easy.
FIXED [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2004 | 09:27 AM
  #49
zorro700's Avatar
I would rather you have the Griz than me too.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2004 | 11:31 AM
  #50
Gopher500's Avatar
lol...i managed to outpull a sportsman 400 once on my kodiak..he had stock tire on grass...thank you 589's.
as of now, i dont even bother hookin up my scrammy.
but then again, they cant run me over if they cant catch me...
but if they do catch me im screwed, no questions asked.
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 19, 2015 06:34 PM
merryman
Sep 19, 2015 03:15 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
