Installing HMF muffler
Old May 19, 2005 | 11:20 AM
coacho's Avatar
Default Installing HMF muffler
I'm installing a HMF utility muffler today. will it hurt anthing if I don't rejet just add the muffler
Old May 19, 2005 | 07:06 PM
OffRder15's Avatar
It might. I would definately rejet in order to get the maximum gains from that pipe.
Old May 30, 2005 | 04:46 PM
pat89's Avatar
You need to put a new plug in and do a plug reading to see where you stand. If you're lean you need to reject right a way. If you're rich, you're wasting potential performance gains from the pipe. If you have a light grey or tan color your okay. I expect you'll be on the lean side.
Old Jun 4, 2005 | 08:08 AM
Starky's Avatar
You're still getting the same amount of air into your motor, so with the new pipe you may be a little lean, but they come on the rich side from the factory. To get the most out of the pipe, you need to open up the airbox. Then you will definately have to rejet.
Which pipe did you get. The regular utility pipe or the QS1.
Old Jun 18, 2005 | 11:53 PM
ridinsmooth's Avatar
yes you should rejet
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
