05 kodiak and 04 Grizzly help!!!
Old Aug 8, 2005 | 12:51 PM
roadwarrior102's Avatar
Default 05 kodiak and 04 Grizzly help!!!
I have an 05 kodiak 400 4x4 and my friend has an 04 Grizzly, they both have the same problem. When goin thru high water or heavy mud they start cutting off like they are hitting a rev limiter or something. Its like they ignition is breaking down and they lose power. Anyone else have this problem!!!!
Old Aug 8, 2005 | 01:09 PM
batmanacw's Avatar
Pack the spark plug boots and any electrical connections with dielectric grease.
It sounds like steam. They are rich from the factory, so when they hit water and create steam, the steam chokes the intake, displacing the air. Mine did the exact same thing. If you rejet with a dyno jet kit, it fixes it completely and gives you more power. A high flow filter would also help because it would lean it slightly and make it alot less likely.
Old Feb 12, 2006 | 12:19 PM
coacho's Avatar
I have this same problem with my 2004 kodiak did you fit it and what did you do
Old Feb 12, 2006 | 06:02 PM
Kodiak660's Avatar
Another thing to do is use dielectric grease on your front diff wires connection.
Old Feb 12, 2006 | 07:56 PM
coacho's Avatar
what wires and where are they located
Old Feb 12, 2006 | 08:03 PM
Kodiak660's Avatar
The wires that plug into your front diff. (servo motor wires)
Old Feb 12, 2006 | 08:39 PM
coacho's Avatar
Thanks I'll try it
Old Dec 28, 2006 | 08:56 PM
shwagg's Avatar
if you have these quads in 4x4 mode front diff locked, they are hitting the rev lim. The override button under the starter button should help out (must hold)
Pgbama11
Jan 16, 2016 08:19 AM
YankeeRebel
Oct 6, 2015 06:44 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
