grizzly overheating
Old Aug 31, 2005 | 05:48 PM
pads's Avatar
Default grizzly overheating
Let the machine cool, pop the radiator cap off and leave it off and start the machine. After it warms up you should start to see the coolant flowing if the thermostat and the water pump are going. If there is no flow, start with replacing the thermostat (that is probably more likely than the water pump). Also, check with your local dealer and see if there were any problems with that year of Grizz.
Old Sep 1, 2005 | 02:29 PM
700r's Avatar
i did that and the coolent does move slowly after warmed up. all grizzlys are known to run hot but not over heat, that is what i heard
Old Sep 2, 2005 | 12:06 AM
Rackman's Avatar
yes check the rad , the corners fill up with mud and you can't see it.
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
