Snowplow gouging gravel
Old Jan 21, 2006 | 07:13 PM
Pakrfans's Avatar
Default Snowplow gouging
Hi all,
I have about 1500' of gravel driveway that I use my 60" tusk plow on, and so far, it works fine. My question is relating to the skid plates. They're about 4 inches across and since I have gravel (not concrete or asphalt) the skid plates don't keep the blade from gouging down into the gravel and throwing it. I do have them set as low as possible. Are there wider / longer skidplates available somewhere or will I need to fabricate something wider myself...?
any ideas or tips are welcome
THANKS IN ADVANCE
Old Jan 21, 2006 | 11:15 PM
IdahoVinnie's Avatar
Default Snowplow gouging gravel
Get some hardened steel and merely weld it to the bottom of your existing skid plates. I cut 2 pieces out of an old tongue--the piece that a trailer ball is bolted to. Very hard steel and lasted for 2 years with very little wear.
kampswas
Sep 23, 2015 05:05 AM
Ean
Aug 28, 2015 09:39 AM
Stever6368
Aug 16, 2015 07:34 PM
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
