mammoth 800
Old Aug 4, 2007 | 06:10 PM
howardken's Avatar
Default mammoth 800
gauge says overheating,but unit is not hot.changed sending unit and new gauage but stil shows hot?
Old Aug 14, 2007 | 05:25 PM
s16's Avatar
s16
Default mammoth 800
ours was showing a little hot.
we went to the parts store a bought a gauge that shows the actual temp. and replaced the orginal gauge. the new gauge never gets over 165
not sure what kazuma considers hot but our unit never ran hot
Old Aug 14, 2007 | 07:13 PM
howardken's Avatar
Default mammoth 800
what type or name of gauge did you get?how did you add water,when i open the radiator cap all the water in the reservoir drains out.
Old Aug 14, 2007 | 11:45 PM
s16's Avatar
s16
Default mammoth 800
got the temp gauge at oreillys. it was a temp gauge that is set up for multi amp set up.
we added water through the plastic overflow tank should be mounted on the firewall under the hood.
let it run till engine warm then tilt the bed and crack the valve behind the engine and drivers seat. crack open until water starts flowing out. if the motor has air pocket steam will come out first. top off the overflow. do this a couple times should get all the air out.
hope this helps
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
shooters
Dunes and Dune Machines
Nov 30, 2008 07:32 PM
Les250cc
Aug 25, 2008 11:43 PM
