Winch brake when using a Swisher Dump Bucket
Old Oct 10, 2007 | 05:28 PM
superdaves's Avatar
Default Winch brake when using a Swisher Dump Bucket
Hi Folks,
I see a few people here have the Swisher Dump Buckets so I'm wondering if I need to get a mechanical brake on my Warn 2500lbs winch. I have a 800 Outy Max XT so I've already had to buy extra parts for the special a-arm mounts and an extension for the Max 2up portion so the last thing I want to do is to buy another part for the winch before I even take the unit out of the box!! I know that you can use a pulley block to lessen the load but have you actually put a brake on the winch to prevent it from collapsing. I see a few articles of the Gorilla winches failing and I'm wondering if it's related to a lack of brake. Thanks!
Old Oct 13, 2007 | 12:12 AM
superdaves's Avatar
Anyone?
Old Oct 15, 2007 | 03:27 PM
Reb2's Avatar
I don't have the Swisher system but after looking at it I would suggest getting the extra brake. Where you already have the winch though you might just try it first. You can always add the brake later if needed.
Old Jan 13, 2008 | 09:28 AM
pat89's Avatar
I have the Swisher Bucket and quickly purchased a brake for my Warn 2.5 after setting it up. It was hard on the winch and switch because the bucket would lower everytime it had a load on it. In my opinion, all winches should come with a brake already installed.
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
