Manual Clutch 4X4?
<div class="FTQUOTE"><begin quote>Originally posted by: BenjaminPQ
If you look on Artic Cat's website the 500 4x4 is indeed a manual clutch with a toe shifter. That is what I am interested in. I still don't know what year they started making them with that configuration. Where are the die-hard AC guys!</end quote></div>
Okay, I remember now (Pretty sure anyway! [img]i/expressions/face-icon-small-happy.gif[/img] ) Arctic Cat started making the 500 manual 4x4 in 1998. It stayed the same through 2001, with 10" ground clearnace and a semi-independant rear suspension(works GREAT!). 2002 it went through a change in body style, and got more hp and became a fully-independant suspsnsion with 10" of suspension travel and 12" of ground clearance. Next generation change was in 2005. 2006 is when they added a diff-locker to the 4x4 system, however the first generation 500's can be made to lock their front dif with no problems.
My old man has a 2000 500 4x4 in the auto. It is a solid maching, and he uses if for everything from yard work, hunting, clearing trees, riding, plowing, etc.
The clutch on these things is a tow/heal shifter. Some people find this really annoying and prefer the "regular" style. Arctic Cat does have a kit for like $40 that will convert the tow/heal shifter into a standard one.
Is that what you are looking for?? Let me know if you have specific questions. Good luck.
#15
instead of having the traditional"put your toe under and click up to up shift and then click down with your toe to down shift type shifter". arctic cat has a rocker type shifter. 5 clicks up with your heal (1st-5th gear). 5 clicks down to down shift with your toe. easier than it sounds once you get used to it.
#18
<div class="FTQUOTE"><begin quote>Originally posted by: mudslinginfool
yes but without the actual clucth you pull in with your left hand. its a "wet clutch". basically you just shift.</end quote></div>
Ok, now I'm really confused! So the 500 doesn't have a manual clutch, just manual shifting?
#19
Ok, now I'm really confused! So the 500 doesn't have a manual clutch, just manual shifting?</end quote></div>
Yes I do not think a manual clutch on a Utility was ever made. (Meaning a hand operated clutch)
#20
haha i confused myself reading this thread
I always called it semi-clutch(kick it up, kick it down), manual or auto..less confusion that way [img]i/expressions/face-icon-small-wink.gif[/img]
The largest utility w/ a semi clutch is a vinson 500 and the AC500 from what I remember.
