04 350 bruin temp sensor issue
Old Aug 25, 2017 | 09:47 AM
67zebra's Avatar
Default 04 350 bruin temp sensor issue
I recently purchased an after market temp sensor for my bruin. The sensor is the same but the connector is slightly different, company says they have sold hundreds of them with no problems. The wiring looks untouched. Does anyone know if there was other types of sensors used on these machines.
Old Aug 25, 2017 | 01:40 PM
Does it hook up to your harness? May be the same specs as an oem but if the connector is the only difference and doesn't work,you should be able to cut the connector off and use the oem connector on the new sensor like a lot of people have done on aftermarket sensors.
