Brakes
Old Dec 24, 2021 | 08:54 AM
DickB's Avatar
Default Brakes
2002 Yamaha Bear Tracker 250. I just replaced the left hand brake cable with a new one. When I pull the handle, it remains depressed. If I push it out to it's normal position, it pulls out of the adjuster on the handle bar. I've adjusted it until the spring in the back is completely tight and still, no help. Any suggestions???
Old Dec 26, 2021 | 05:02 PM
nny's Avatar
nny
replace the cable
or remove it and work water repellant dry lube down the cable.
Old Dec 26, 2021 | 09:11 PM
DickB's Avatar
It is a new cable, the problem was in the adjustment. Problem solved.
Old Dec 26, 2021 | 10:25 PM
nny's Avatar
nny
cool glad you got that figured
intheworks
Technical and How-To Articles
Sep 11, 2017 10:31 PM
tyanna
Mar 16, 2009 08:33 PM
Crayton8700
Nov 17, 2004 02:36 AM
soon2bBlaster
Jun 29, 2004 09:39 PM
ktk
Mar 21, 2004 10:59 AM
