Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Noise when braking
Old Oct 26, 2007 | 06:41 PM
Rhino London's Avatar
Default Noise when braking
has anyone experienced a loud grinding noise when they are on the brakes, even though the brake pads are good?
Old Oct 29, 2007 | 09:50 PM
pwillie's Avatar
Yep! I don't know why!
Old Nov 12, 2007 | 06:13 PM
have you spoken to anyone about the problem? no one can tell me what the cause is.
Old Nov 13, 2007 | 11:15 PM
staceyandtony's Avatar
Cory at desert toyz can take care of that problem hust give him a call
Old Nov 14, 2007 | 10:55 AM
do you have a phone number for Cory?
Old Nov 19, 2007 | 04:37 AM
cobra2813051's Avatar
If the grinding is coming from the rear, check the rear brake disc. It is more than likely a little loose. Just torque it down a little and it will be fine. If you have the time, I recommend getting some blue Lock-Tite thread lock and applying a bit to the bolts when you are down there working on it. I would not recommend using the red Lock-Tite because its bond is too strong in my opinion and can make for a difficult disassembly when you have to replace the pads. Good luck!!!
TheCobra
mrtidy
Feb 3, 2016 05:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
