Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Rhino snorkel materials help
Old Feb 29, 2008 | 12:20 AM
oldatvr's Avatar
Default Rhino snorkel materials help
I own a 2006 Rhino 660. I want to snorkel it but having trouble finding 2 1/2" I.D.
flex pvc hose for air intake. All local sources can't help. I live in Raleigh area of North Carolina. I also need 2" for the drive belt housing .
2 1/2"x 8' 12'x 2"-can anybody help with a souce? oldatvr
bdooners@hotmail.com
Old Mar 1, 2008 | 02:07 PM
DUFFSTER's Avatar
I just bought a 10' section of 2-1/2" flex hose for my air box snorkel. You can by it in 5' increments or a full roll of 25'. Part # is 5475K87, 5474K86 is the a 2" ID bought it at McMaster-Carr, www.mcmaster.com. Grainger also carries it but have to buy full rolls thru them. The stuff I bought is pretty flexible, they sell other types of flex tubing that are more rigid if thats what you need(each item has pretty good description of it bend radius and durability), just look thru the few pages they have with the flex tubing on there online catalogue. Rich
Old Mar 1, 2008 | 08:44 PM
ProEMTPFF's Avatar
Anyone have any pictures of thier design? I'm wanting to snorkle my 2007 Rhino and don't have a clue what do do or where to start.
Old Mar 1, 2008 | 10:25 PM
oldatvr's Avatar
Thanks Rich, I will use your sources asap. Good riding!!
What state do you live in? We planning our 3rd Hatfield W.Va.trip for this spring. What a great place to ride! Les
Old Mar 1, 2008 | 11:13 PM
DUFFSTER's Avatar
Les, I live in Phoenix. Good luck with your project.
ProEMTPFF, There's a few different types and reasons to snorkel. Do a google search for "yamaha rhino noise" and a link comes up for a site www.rc-trucks.org/yamaha-rhino-accessories.htm, it has a flex tube snorkel to eliminate engine noise, it's not the best idea if your looking for a water tight up high fresh air intake. You can also try www.rhinoforums.net, it's temporarly down do to a dns problem but should be fixed in a day or two, it the best site for rhino info and it mostly a bunch of us local guys from the PHX area. Good Luck. Rich
Old Mar 2, 2008 | 04:47 PM
bucky2's Avatar
I have been wanting to do the same thing to my 450. We put a windshield and
a roof and that made the noise really ugly . please let us know how it works
thanks
Old Mar 8, 2008 | 11:34 AM
bucky2's Avatar
I hope that you have better luck with the projet than I have had.I installed
the 2.5 inch hose exactly as speced out . I am disappointed, my 450 runs
like crap. how are you doing with yours
Old Mar 9, 2008 | 11:50 PM
DUFFSTER's Avatar
We'll I got the hose(2-1/2" size) and got everything apart and then realized that the 660 engine doesn't have the rear motor housing/console clearance like the 450cc engine does. I could get it to fit/work but I'm not looking to cut up my console to make it fit.
If anyone wants to buy my 10' section of hose I'll sell it for $30. I will say that the hose from McMaster-Carr is really heavy duty and super flexible. It's definately not a cheap plastic type shop vac hose which is what I was expecting.
Bucky, what's going on with your running issue. You may just need a simple carb adjustment. Rich
Old Mar 10, 2008 | 05:24 PM
bucky2's Avatar
I dont know whats wrong , when in wet type of weather it misses and seems
to have a lose of power. I dont know whether to pull the hose out or mess with
it some more.
was it the console or the air intake that needs trimed ?
Old Mar 10, 2008 | 09:54 PM
DUFFSTER's Avatar
There's no room for the tubing to go out the top/back of the engine and drop around the cvt cover area, the 660 has all sorts of plastic ducting and such and the engine cover fits like a glove no room for anything. The 450cc engine is wide open in that area.
Does the engine run fine at idle ? and acts up on accell or running top speed ? Either way it sounds like a simple carb adjustment, find a good shop that can fine tune your engine/carb thru all rpms with the set up and you should be fine. Rich
