Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Overheat issue
Old Mar 9, 2008 | 10:17 PM
Chad13's Avatar
Default Overheat issue
Can anyone provide some information about the electronics on a Rhino, specifically the temperature sender and overheat light?
I have a 2007 rhino and it over heated while running through sugar sand all day in about 90 degree weather. No surprise.
So, I installed a switch to keep the electric radiator fan on if needed and it appears to have resolved the engine overheating problem.
However, now the overheat light comes on 5 minutes after the engine is started even though the engine is not really hot, confirmed with thermometer.
So I bought a new temperature sensor sending unit, the one mounted on the thermostat housing not the radiator, because I assumed I had cooked the original sensor. Unfortunately, I am still getting the false over heat light. Any suggestions to resolve the false over heat signal are welcome.
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
Unzzy66
Jul 11, 2015 10:01 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
