Raptor Camber Settings ???
Old May 22, 2003 | 08:43 AM
Murph66's Avatar
Default Raptor Camber Settings ???
I am finally getting around to installing my +2 a-arms. The manufacturer recommends setting the camber at 0. The type of riding I generally do is generally all out fast trail riding to GNCC type riding. Should I set them with 0 camber or should I put some camber in it? I could use some expert advice. Thanks.
Old May 22, 2003 | 09:21 AM
Hiram's Avatar
A like using some negative camber, helps it hook up more on turns and prevent them from sliding as much on the turns by keeping more of the tires bite/thread on the ground as it rolls under from the force.
Old May 22, 2003 | 10:11 AM
Murph66's Avatar
Thats what I was thinking too. How does it affect turning in the low speed tight stuff?
Old May 22, 2003 | 10:19 AM
Hiram's Avatar
It's an all around improvement. Before my adjustable extended a-arms my quad would tend to push the front tires and not turn until I leaned my wieght to the opposite side if trying to turn sharp from a dead stop or slow speed, not any more I can turn the wheels all the way from a dead stop even on loose dirt and it just turns without having to lean,
Old May 22, 2003 | 10:20 AM
Murph66's Avatar
How much negative camber do you run?
Old May 22, 2003 | 11:03 AM
Hiram's Avatar
The easiest way for me to say would be 1/4" without the rim on the spindle, I measured by using a level placed against the bottom of the spindle edge were the rim is bolted on to the top bolt on the same section of spindle, I think it's about 3 turns out on the bottom adjuster of the lower a-arm and the top a-arm adjuster bolt all the way in. I used a level beacause one side has more turns out than the other the a-arms are not perfect at least the ones I have.
I also adjusted the caster back about negative 1/2" from the bottom pivot spindle point to the top one, in case your are adjustable it helps with high speeds.
Old May 22, 2003 | 11:11 AM
Murph66's Avatar
Cool. Thanks Hiram
Firefighter400
Oct 8, 2022 06:38 PM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
black_thunder
Aug 19, 2015 03:23 AM
black_thunder
Jul 22, 2015 06:01 PM
