Make my wolvy faster and sportier
Old May 26, 2003 | 03:10 PM
WolvyRider's Avatar
Default Make my wolvy faster and sportier
Does any one have any sugestions for aftermarket parts or modifications to ad speed and make my wolverine sporty, it already preety quick and sporty but i want more!!
Old May 26, 2003 | 03:18 PM
WolvyRider's Avatar
yo im a 15 year old jew.....there are many tips or ways on helpin makin your atv better..u hafta take off ur air filter and put better spark plugs and ull fly buddy! peace ur welcome
Old May 26, 2003 | 03:21 PM
WolvyRider's Avatar
sory guys that last reply was not me it was one of my buddies f**kin around!!!!!!
FRIGIN IDIOT!!!!! found out my password
Old May 26, 2003 | 03:32 PM
RoostItUp's Avatar
filter, pipe, jetting, and tires. The kinds you want are up to you. I'd recommend for filter a K&N (if you ride dirt or mud then UNI Foam) for pipe it's hard to say cause I don't know what kind of power your looking for, lookup previous posts about wolverine pipes. Jetting I say go with Dynojet jet kits and tires are up to you with the type of riding you do. GL
Old May 26, 2003 | 05:15 PM
MojaveRider250's Avatar
Get a pro circuit T4 it works with my warrior so it probably works with a wolverine.
Old May 26, 2003 | 06:46 PM
spike82228's Avatar
I second the Pro Circuit T-4, I have that for my wolvy. It added alot of low end and midrange power. I also have the parts below, but i still need some better tires.
Old May 27, 2003 | 01:02 PM
WolvyRider's Avatar
How much of a difference does a K&N and a dynojet kit make, im looking into them, is it worth the price
Old May 27, 2003 | 01:17 PM
BomByDuDE's Avatar
Yo man. I'd say just make ur wolvy for the mud. wolverines are the best mud quads u can buy. take of your air box aswelll as take of ur pipe that should giver it a nice sound!! hope this helps.
Old May 27, 2003 | 02:07 PM
Murph66's Avatar
Others will probably object but this is the truth as I know it. Not Much. The wolvy has a fairly good flowing exhaust. Look at your headpipe diameter. Jet kits are also a waste of money with a bunch of stuff you don't need. If you put a pipe on it all you would need to do is probably go up one Mikuni jet size for 3 dollars, if you even have to do that because of what I said about the exhaust. If you really want to make your wolvy scream then you are talking big bore, higher compression etc..... If your not going to do that I would keep it stock unless you just want to make more noise. There is something to be said for intimidation factor when you are nipping at someones heels. Get a clamp on air filter and adapter. If you ride in any muddy conditions get a foam filter not a K&N. Spend your $ on some good tires like razrs and works shocks for the front. Lose the racks and do what you can to make it lighter. This my advice. Do what you want with it.
Old May 28, 2003 | 12:04 AM
CruzNlife1's Avatar
If you want something sportier, i'll trade you one of my banshees, 89 Original plastics, mint condition, motor just overhauled, new tires, brakes, seals, chain and sprockets.... yada yada yada.... i want a 4x4 !!
