Wolverine not running
Old May 26, 2003 | 10:18 PM
Lucky13's Avatar
Default Wolverine not running
My wolverine stopped running this weekend. I finally got it started, but as soon as you would rev it up, and let off it would die(It also sounds like it's misfiring). Then I got it to the point where. Then I got it to idle, revved it up again , and die again(still misifiring). Now the plug is black. changed it didn't solve it. Any ideas. I ohmed out my ignigition coil, between the spark plug cap and the lead and it ohmed out at 16K ohms, but I was still getting spark. Is this the problem? Is it not burning hot enough.I ohmed out the CDI and according to the book it still sounded good. I just recently put a white brother pipe on it, but did nothing else(no rejet or anything). Any suggestions or help out there. I'm not really comfortable with tearing apart the carb, so I don't want to mess with that, if all I need is an ignition coil.
Help
Lucky13
2001 wolverine with white brother silencer.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 27, 2003 | 11:05 PM
Lucky13's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]Can anybody Help? I checked the parking brake switch(not it either) can valves cause this problem? CDI? Carb? any suggestions, somebody, anybody?
Lucky13(maybe a little unlucky right now)
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
