Raptor timing?
Old May 27, 2003 | 11:01 AM
racereadyraptor's Avatar
Default Raptor timing?
Is there any gains to be had by advancing or retarding the timing? Is it tricky.....
Old May 27, 2003 | 12:22 PM
ttt
Old May 28, 2003 | 10:48 AM
Last chance
Old May 28, 2003 | 02:59 PM
Ward660R's Avatar
advanced will give you some more bottom, retarded will give you some top. Too much advance and you could get some detonation on pump gas.
Its not tricky.
Old May 28, 2003 | 03:09 PM
That does not sound to bad.Have you retarted yours?What is the procedure?Is it a noticable gain?
Old May 28, 2003 | 06:36 PM
Ward660R's Avatar
I did but not on purpose, worn cam chain and stuff. It was retarded 6 degrees. You can do the same thing by slotting the cam sprocket and dialling it back. I can't really say how much I gained from it because it was over time, kinda. But I gained low end when I went back to the right timing.
Old May 28, 2003 | 06:41 PM
Thanks for your help.
I don't know if all that work would be worth the "maybe more HP" though. If I end up doing a 686 I'll have the tech to do it then.
Take care.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 18, 2003 | 07:35 PM
Hiram's Avatar
Ward, I was looking at this timing thread and believe what you described is more for timing the opening and closing of the valves to degree of the piston at TDC.
Correct me if Im wrong, But what is really needed to experience a performance gain is spark timing to degree of piston at TDC. Has anyone had any experience with doing this to the Raptor.
Old Jun 18, 2003 | 09:21 PM
sixsixT's Avatar
Your right Hiram, Ward was talking about cam timing. If you want a little info on ign. timing check out some of the Dyna CDI threads but there's not to much.
Old Jun 18, 2003 | 10:18 PM
Ugintel's Avatar
i bought the degree key and advanced my timing, it wasnt worth it.... it actually gave me more bottom end but made my bike slower so i bought bigger paddles and regeared it and it's a little faster then before but wasnt worth the 600 bucks i soent in paddles shipping gaskets and all that other crap to do it (flywheel puller).......
