Blaster Problem!!!!
Old Jun 10, 2003 | 12:43 AM
BlaSteRidr's Avatar
Default Blaster Problem!!!!
Anyone else?
Old Jun 10, 2003 | 12:44 AM
dirtrider078's Avatar
get some vice grips and get those screws out and see what is wrong also do you have your clutch cable adjusted right
Old Jun 10, 2003 | 12:46 AM
BlaSteRidr's Avatar
the clutch cable is adjusted right, I am waiting on a screwdriver that you can hit with a hammer that gets those screws loose.
Old Jun 10, 2003 | 12:50 AM
i would have to go with a tranny problem. that would be my best guess wiht out hearing it.
Old Jun 10, 2003 | 01:25 AM
  #15
BlaSteRidr's Avatar
Ok thank you for your help, I will try that. The only reason i didn't is because it did it at idle and i dont see how the tranny could be involved, but i will check.
->>>anymore help would be appreciated.
Old Jun 10, 2003 | 02:05 AM
  #16
raptor8's Avatar
sounds to me like a seizure that broke loose. if you cant find anything else wrong, popo the head and barrel off and look at the piston...if it tried to seize it'll have a big scrape mark on it. youll know.
when they seize they dont always stick. can breal loose quickly..but check it JIC....
Old Jun 10, 2003 | 12:31 PM
  #17
i just read in my manual that it could be a compression leak if i understood it right.
Old Jun 10, 2003 | 06:30 PM
  #18
BlaSteRidr's Avatar
Thank you raptor8, when i check, if i find out that it has seized, how can i fix it?
Old Jun 10, 2003 | 06:52 PM
  #19
raptor8's Avatar
look closely at the bore in the barrel. if it has seized, it should be marked. just take it to a shop and have em bore it out a little. new piston too of course...
hope its something simpler....
Old Jun 10, 2003 | 06:54 PM
  #20
BlaSteRidr's Avatar
Ok i will check now, thank you for your help raptor8!!
