89 shee for $2000 ??? Or wait for a better deal
Old Jul 23, 2003 | 06:29 PM
LAZYHammer's Avatar
Default 89 shee for $2000 or wait for a better deal
I have a chance to get an 89 banshee with PSI pipes, DG bumpers front and rear, an AMP link, V-force reeds and nice tires, oversized carbs, and newer plastics.
It looks pretty nice considering its an 89, Im not too bright with 2 stroke motors... so how long will it last if I would rebuild as often as need be, also I am mainly buying it to modify and customize as a display quad for my co. and get som fullbore plastic... the good thing is, its not too far from where I live.
So should I check it out?
Mark
Old Jul 23, 2003 | 06:35 PM
ElectricShift's Avatar
Default 89 shee for $2000 ??? Or wait for a better deal
go on up there, check it out...maybe test ride a little, and see how you like it.
Old Jul 23, 2003 | 07:10 PM
LAZYHammer's Avatar
Anyone else? it also has a boost bottle and k&n filters
Old Jul 23, 2003 | 07:30 PM
TyreSpinner's Avatar
Man it really depends what condition it's in...If it's been used and abused...I'd forget it.
Take it for a ride...if it rips a good more than a stock banshee, and check for the signs of abuse, get it [img]i/expressions/face-icon-small-happy.gif[/img].
Jeff
Old Jul 23, 2003 | 08:05 PM
Yamaha660R's Avatar
Yeah, 89' is old.
But it could be well taken care of.
Check it out.
Old Jul 23, 2003 | 10:15 PM
LAZYHammer's Avatar
Anyone else?
Old Jul 24, 2003 | 10:00 AM
LAZYHammer's Avatar
It looks very well taken care of, I think I can talk him down to 1800 I see it has ohlins front shocks with rez's on, do they come stock with them?
Old Jul 24, 2003 | 10:02 AM
LAZYHammer's Avatar
Oh, and what is an amp link, and are psi pipes any good?
Old Jul 24, 2003 | 11:36 AM
LAZYHammer's Avatar
I need to know ASAP, like I said, it looks very well taken care of.
Old Jul 24, 2003 | 12:19 PM
MOJAVE02's Avatar
if compression is good and there are no apparent signs of being beat(bent frame, broken parts, etc...) then get it. by the way the PSI pipes are fairly good. really any aftermarket exhaust will help the banshee greatly when properly jetted because it is so choked on the top end from the factory. no ohlins shocks do not come on it from the factory, and yes they are a very good shock. to me if it looks good buy it even for $2000 it is a good deal for that awesome bike. i like to re-ring my bike every 60-80 hours just to be on the safe side, it is $60.00 which is very cheap maintenence for longevity. an amp link keeps constant tension on the chain for better power transfer to the rear wheels and when jumping it keeps everything in tact. full top end rebuil probably every 150-200 hours depending on condition of piston, cylinder, and the way the bike is ridden. trust me it is a very simple engine to work on. good luck.
mark
