Raptor 660R problem.. help?
Old Jul 24, 2003 | 11:59 PM
Dan660R's Avatar
Default Raptor 660R problem.. help?
i got my new 660R about a week ago and i got stuck in sum mud ( hell id call it quick sand if it wasnt black ) and im tryin to rock it by goin from first to reverse ya know? an ever sence then i can go in reverse, its like i burned the gear!? wtf? its only like 2 hours old. could there just be somethin loose or simple to check out? also could this affect all the other gears? an the general performance of the machine?
Thanks
Dan
Old Jul 25, 2003 | 12:06 AM
warrior007's Avatar
You sure its ok in the forward gears? if not it could be the clutch. Put the motor under load (full throttle roll-on) in 4th or 5th gear to check.
Its possible you may have spun the reverse pinion on its shaft, it is only pressed on and not keyed, this is the first possible failure I have ever heard of. To see the shaft and what I am talking about you can go Here
Old Jul 25, 2003 | 12:20 AM
Dan660R's Avatar
so then it seems like maybe something my warrenty would cover? should it cost alot of $ to fix? i hope not... [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 25, 2003 | 12:25 AM
warrior007's Avatar
If you bought it a week ago it should be covered 100% but clean it real well so they cant say you abused the machine.
Old Jul 25, 2003 | 12:44 AM
sixsixT's Avatar
Might just be the cable to allow you to shift into revrese is misadjusted.
Old Jul 25, 2003 | 02:04 AM
Yamaha660R's Avatar
I would shine it up real nice, and take it back to the dealer. Tell them you don't know what happened. LOL
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
