Lowering front end for grass drags.
Old Jul 25, 2003 | 01:31 AM
Hayseed's Avatar
Default Lowering front end for grass drags.
I think I read it in a post on here once that Warrior shocks will lower a Raptor's front end 3". This would give me the weight transfer I need for local grass drags. I figured I'd do this instead of building solid struts in case there are suspension mod rules. Does anyone know if this works?
Old Jul 26, 2003 | 12:06 AM
RaptorRacer1's Avatar
Probably for about the same price as buying used shocks you could just buy front lowering blocks. They only work with the stock style shocks, but they will lower it about 4". I had them for awhile, but they don't fit my Elka's so I need to get rid of them. Just an idea!
RR1
Old Jul 26, 2003 | 01:11 AM
THEMOOSE's Avatar
Shorter shocks or lowering blocks would be best for grass & dirt drags,
I use struts on sand drags but they may damage your mounts on a rough surface.
Old Jul 26, 2003 | 02:29 PM
87Banshee250sx's Avatar
Is there ever a loss of traction in grass drags? I remember over the winter when I had ice studs in I drove on the grass with them and it got sooo much grip. I was wondering if that was legal in grass drags...
-nick
Old Jul 28, 2003 | 12:40 PM
Hayseed's Avatar
87Banshee250sx, The reason for lowering the front end is to lose traction, not gain it. It gives you needed slippage to keep the front end down on takeoff. It is also harder to pick up front end weight that is sitting lower than if it were higher.
Thanks everyone.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
carolinabomb
Jul 26, 2015 08:40 AM
musselmark
Jul 17, 2015 02:40 PM
